Valve cover bolts
kyhook
New User
I want to remove the valve cover on my 850 Ford. The acorn nut came off of one of the studs. When I tried to remove the other one, the stud turned and would have come out. I stopped because l thought maybe the stud could be holding something more under the valve cover. Is it ok to remove the stud and get the acorn nut off it.
Thanks
Let the stud come out, only inch and a half long. will give you more room to roll the valve cover out.
