Still oring problem
The smaller of the two orings will fit in the front recess. But, when I tighten it up it leaks. I cannot get the larger of the orings to go up into the recess. I am about to call it quits for the day. Can someone tell me the diameter of the recess and what the outside diameter of the large oring is supposed to be. The rings that came out of there were hard rubber and flat. Thank you
