pto shaft collar seal
wpc45
Hello. I need to replace the pto seal in a Ford 4600. The collar the seal contacts on the shaft is worn and I have a new one to replace it with. My question is how to remove and replace it? I assume it is pressed on and I will need to heat the new one to expand it and slide it in place before it cools. What is the best way to remove the old one? Split with chisel length wise, cut length wise with dremel, heat?
