The diff lock pedal on my 3000 is locked up, and I broke the linkage between the pedal and arm. Is there are source for new ones (or something that will work the same), or should I source a used one? I can get a used one for about 40$.
Also Ive read that I can break the diff lock free by putting penetrating oil on it a few times, and working the arm. Will that work or is there something inside the diff I need to mess with? Im going to have the hyd cover off soon, and thought maybe I could get to it from there.
The diff lock worked on the tractor when I got it, but I some point became frozen because of lack of use.
