Im at my property which is 2hrs from civilization. The 850/860 tractor I just bought aint working worth a poo. Its like I have next to no torque regardless of what gear Im in. I dont even have enough torque to push into a pile of loose gravel to take a scoop, regardless of engine RPM.
The peddle it set at furthest hole in the fork so that the pedal itself is only about 5 off the floorboard. I did notice that it seem like I get torque if I pull up on the clutch pedal...almost like when I let off the pedal it isnt engaging far enough.
Does this mean the clutch is shot?
Or do I need to pull the pin and adjust the fork so that the linkage becomes longer?
Help please. Im only here 1 more day and Ive got 2 dump trucks worth of gravel in my driveway.
