7000 hydraulic adapter plate.
KYCASE1
Is there an adapter plate made, that mounts between the hydraulic remote valve and the tractor for a loader. I know the make them for a 5000
but not sure about the 7000. Anyone know were to find one? Thanks for the help.
The parts site shows everything is the same between the hydraulics of a 5000 and a 7000 unless it has load monitor. So if it doesn't have load monitor I would think the the same adapter plate for a 5000 should work, unless yours is a row crop model with the flat deck, then there probably isn't enough room to stack everything under the deck. Others with more in-depth knowledge of those models than I may come along and correct me if I am wrong.
All 7000s had Load Monitor to the best of my knowledge, just like 76/7700 (except FWD) models. That said, I don't know why the porting for the adapter plate would be any different between a LM and a non-LM tractor.
