FORD 600 3point
GaryinKs
I have a Ford 600 that we have had for over 40 years , the 3pt point has always worked OK , now it will lift all the way up no matter where the lever is set , no matter if I am using it or it is just sitting there idling, does anyone have any idea what is causing this? The oil is filled to the proper level and the tractor is on level ground.
(quoted from post at 18:55:48 04/07/21) I have a Ford 600 that we have had for over 40 years , the 3pt point has always worked OK , now it will lift all the way up no matter where the lever is set , no matter if I am using it or it is just sitting there idling, does anyone have any idea what is causing this? The oil is filled to the proper level and the tractor is on level ground.
ow long has it been since the last time it functioned properly? Hours, days, weeks, months, years????
