5 speed transmission
What's a good 5 speed transmission, live pto version, worth with the clutch? Motor and hood going to a couple other projects, rear end casting has some damage, tires mismatched and three not much good anyway, 3 point lift needs work. Debated to rebuild and find a rear end but tires, a couple wheels, brakes, replace rear end, fix hydraulics, paint, would need new fenders. Seemed better to let this one help finish a couple other projects. I drove the tractor around, shifted fine, didn't jump out of any gears. Went up and down some hills. I have no idea how new the clutch is just that it works. Motor will come off the tractor later this week or next week end.
I can't tell you what it's worth in dollar figures, but if it didn't pop out of 3rd or reverse gears, it's got some valuable
parts inside for somebody.
It did not. Drove it around for a while, up hill and down in reverse and third, give it throttle and back off while going down hill. Never did jump out of gear. Tried 4th and 5th same way. Seem to shift smooth in all gears. Tempting to get parts and get this one in good condition but this being a donor will help get a couple other tractors back to work. And I could put the 5 speed in my 841. Thanks for the response.
