I finally tired of sputtering, backfires through carb, flooding, fiddling with points, uneven power output, etc. Not a whole lot of hours on a rebuild of the original carburetor and replacement points.
Ordered a Zenith carb. It bolted right up.
Ordered a Pertronix 1231 kit. Took a hole saw to the points cover to allow the magnet to fit, ran a wire to the battery side of the voltage stabilizer on the instrument cluster.
I goofed on compression/exhaust and it didn't start. Spun rotor 180 degrees. It chugged first crank and idled right down like my car, without any choke, after 10 seconds. If the tractor continues to run like this, the replacements will have been WELL worth the money.
