Early 70's 2000 gas 3 cyl.
Starts easy, runs good for maybe 10 minutes. Starts to bog down, miss, black smoke out exhaust.
Discovered today after running it a short time the bottom radiator hose was warm but the top radiator hose was very hot. Radiator near full. Water was hot but maybe not as hot as the outside of the top hose.
Also almost burnt my hand on the intake manifold. It was literally just as hot as the exhaust manifold.
So what is going on here?
The waterpump failed a year ago (bearing, spitting water around fan shaft) and I replaced it. I do not recall if I replaced the thermostat (I assume it has a thermostat) but I'm sure I would have replaced it at the same time as the pump.
Ideas? Suggestions? Thoughts? Things to check? Things to look for?[/b]
