Ultradog MN
- Location
- Twin Cities
I'm wondering how much Kenny's loader will
lift.
Did a bit of searching and found the info
below on Tractordata.com.
It says either 3500 or 4500 lbs depending
on whether it is a direct linkage loader or
a 4 bar linkage loader.
I'm not sure what the difference is.
Can someone tell from these photos?
Note that the link at the bottom on this
side is not connected. Is that what they
mean by 4 bar linkage? We never did use the
forks hard so we never got around to
modifying the fork mast so it would fit
properly.
I might? have a project coming up that I
need to lift about 3500 lbs a couple feet
high but would lift from the main lift arms
BEHIND the forks.
We do have about 1400? lbs on the 3 point
and could cobble some more weight on if we
needed.
Tractordata
lift.
properly.
BEHIND the forks.
needed.
Tractordata
