Looked through old posts and have a question about crankcase pressure. Keep in mind I am not a motor head or a diesel guy, just a dude who tries getting things done.
I have an 861 Diesel and runs great, I haven't noticed any problems.
I ran out of fuel cleaning snow the other day.
After that I couldn't get it to fire, it would just crank. I then realized how bad it is to run a diesel empty!!
Trying to get it to fire after refueling, I loosening the fuel lines from injectors, checked for fuel at filter, messed with oil stick, ended up doing to worst thing and gave a quick shot of ether to finally fire it up.
Then it ran good again, and went out a day or two later and after letting it warm up, I noticed oil coming out of the oil stick tube. I have not noticed this before. I did have a few issues a couple months ago where the tractor was a little harder to start from cold, but I definitely think I would have noticed the overpressure with the oil pouring out of the oil stick tube, as didn't take long to notice and I didn't see any old oil puddles where I park it.
I haven't really noticed if there is more/less smoke, but the stack has a decent amount of white smoke is all.
I checked all the fuel lines and the oil stick cap and did find that I had loosened the tube that goes into the fuel injection seal as the line coupler did not break loose. I tried correcting that issue and but did not work.
If I let the tractor sit for 20 minutes, then start, it fires up and it takes about 15-20 minutes before the oil starts pouring out. I don't notice any power loss etc.
I don't really know anyone else who uses these old tractors and just wanted to ask knowledgable people a couple questions.
All signs point to rings, does this make sense with what I've got?
Would an In-Frame Rebuild Kit (Sleeves, pistons, rings, pins, retainers) be all a guy would need to try to repair this?
I have a few things I am going to really need to use this tractor for late spring/early summer so I don't have much of a choice and need to try to get something figured out. I have a couple weeks off next month and just need to get a game plan together and parts so I am ready.
It is a good running tractor, and has plenty of character, but I really like it.
Any help is appreciated.
I will try to give everything a good cleaning when I do the job, right now I am still covering everything in oil.
Thank you all.
Haven't been able to post pics or clips, blocking post.
Thank you all.
