CONSERVATIONMAN
- Location
- SE Wisconsin
Tractor was running until it got real cold out (-5 or so)
Don't have any spark. I can get spark if I short across the points.
I measure 6 volts with points open and about 4 while I spin it over.
Measuring the condenser (Across open points, ignition off) whith a digital meter it starts out as a short and charges up to read 2.5 ohms.
If the condenser is the problem could I remove it and get a spark to see if it will run?
What do you think?
Thanks
What do you think?
Thanks
