Company Logo Shop Now
Order Ford 3000 Parts Online
Universal seat for 3 cyl 3000 or 4000
JK-NY
02-23-2021 10:58:08
Has anyone here used one of the universal replacement seats like you see at TSC on a Ford 3 cyl 3000 or 4000 ? My old original seat is really shot and I wondered how well one of these replacements would fit/work.What I have now is the OEM Ford "tip-up" style seat that allows you to raise the seat pan and tilt it to keep water off/ easier on/off. Thanks in advance for any replies.
RobCons
02-26-2021 18:38:26
 Re: Universal seat for 3 cyl 3000 or 4000 in reply to JK-NY, 02-23-2021 10:58:08
I dont like them. I'm a little taller than average I guess at 6' 4" and they sit me up to high. Puts the steering wheel at almost knee height. I have to bend way over to reach the controls.
ptfarmer
02-26-2021 17:01:29
I have one for about 3 years now, and it's holding up well since I keep it covered when not it's not in use. For the price it's not bad, and the adjustable suspension on it treats my back good.
Texasmark1
02-26-2021 12:40:16
That style is popular as it works. I am real picky about my seats and I probably have half a dozen different types sitting around the shop where I changed out seats on various equipment to get a soft ride. I like that seat because the back rest is in the right place and the back has an adjustable angle, besides having a good price and fitting the Ford series tractors extremely easily and functionally adapted to suit.
The first thing I do is to remove the pin in the top of the shock absorber mount....sitting right there between the 2 springs on the back panel and just push it down till it stops. With that out you have about 3 and a half inches of smooth, non-jarring, deflection that you can adjust to suit you, smooth as silk. If you worry about hitting bottom with it set up for a soft ride, just go to $ General and get one of their foam toys that looks like foam pipe insulation but is in vivid colors with a much thicker wall thickness and cut off a length that fits under the seat. Bingo, problem solved.
showcrop
02-24-2021 05:12:17
As others said keep it out of the sun. It will last a year kept out doors or five years if shedded.
Matt in oz
02-24-2021 02:54:56
Put aftermarket seats on a 3000 and 5000 which work well. Had done this a couple of times over the years as vinyl cover wears out and the foam won't last uncovered. Investigated seat covers and could't get any. Had an upholsterer make up two for the new seats, cost as much as the seats. These tractors are sheded but our heat and high UV gets the vinyl. Have had no problems so far.
GB in MT.
02-23-2021 20:41:57
I bought this one, right here on YT, for my 3000. I like it! Ya just don't want to leave it out in the sun/weather too long.
GB
Hobo,NC
02-23-2021 15:38:14
I got a clone replacement from Sparex S.28985, my old one was worn slap arse out. I put the clone on and parked it back under my shed. I can not tell ya yet if its worth the price...
Lynn Patrick
02-23-2021 15:24:53
Got them on my 3000 & my 2110. They bolted right on w/the 2 bolts that held the original seat. I like them much better!
Shaun Wallace
02-23-2021 14:24:23
Have one on 5000 and one on 801.
rvirgil_KS
02-23-2021 11:13:27
Got one on an 8N and 5610. Get them adjusted and they work good.
Fordfarmer
02-23-2021 11:08:10
I have them on my 4600 and 7000. They're pretty good, although the seat is not quite as big or as well cushioned as the original Grammar. The vinyl does not hold up as long, either...
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
Latest Ad: Farmall 350 , 450 and 560 utility fenders. Excellent condition original. Can send pictures if interested [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
