Ford Tractors Discussion Forum |
1971 Ford 4000 SU front axle swap
Author |
[Modern View] |
Wilbur1975
02-21-2021 20:01:05
I've got a 1971 Ford 4000 su and was wanting to know if the axle and cradle from a 5000 Ford would be interchangeable? Thanks for your time
Shetland Sheepdog
02-24-2021 15:47:32
Re: 1971 Ford 4000 SU front axle swap in reply to Wilbur1975, 02-21-2021 20:01:05
Agree with what Ultra said!
HTH, Dave
Ultradog MN
02-23-2021 01:33:27
If you are looking to make your front end heavier the easiest - and probably cheapest way would be to put a front axle from a 3400 on it. It would use the same power steering system and tin you have now.
Destroked 450
02-22-2021 12:57:41
The early models did use a manual box with the cylinder in the bolster but it was still reversed due to the way the linkage reversed the direction the wheels turned worked
On the manual steering models the steering link went straight from the box the the left spindle like a 4000 thus operating in the same direction has a 4000 box
Sean in PA
02-22-2021 12:28:54
Thanks, good to know. So it's only the later style p/s gear with the internal piston for the 5000 that is reversed? I think that the early style with the external cylinder under the nose used the manual gearbox like the early style 4000 p/s models with the external cylinder on the left side did.
Destroked 450
02-22-2021 07:33:29
Because of the way the steering is setup in the front bolster the steering box on a 5000 is reversed.
Found that out on my 4500 that has similar steering to a 5000, yoke inside the box was broke so I bolted on a spare 4000 steering box, after I got everything installed I turned the steering wheel to the left and the tires turned right, turned to the right and tires went left, ended up rebuilding the 4500's steering box and swapping it back on.
5000 manual box turns same as 4000.
Sean in PA
02-22-2021 06:37:04
The steering box from a standard 3 cylinder 4000 ag chassis model should work also. The radiator mounts may be different on a 5000 bolster as well, but I'm not sure, so you may need to replace the radiator, but as I said I'm not 100% sure on that one. Of course, if the donor 5000 has power steering then you will need to bring all of the power steering components along as well. If the 4000SU also already has power steering, the pump will probably be sufficient at 650 psi, but while the 5000 steering system was designed for an 1100 psi pump, the 4000SU tractor itself weighs less, so I would think that 650 psi should suffice. Also, if the two power steering systems have the different (early vs. late style) pumps, then you will be fabricating new lines.
Destroked 450
02-22-2021 06:26:46
It will bolt on but you'll need a 5000's steering box and will have to fab a drag link, one for a 5000 would be to long.
You'll also need a 4/5000 front grill shell, SU uses one for a 2/3000 and I'm not sure about the hood fitment.
Once you get it together you have a tractor setting several inches higher in the front than the back unless you install the taller 4/5000 rear tires and wheels.
If your wanting to swap to a heavier front axle find one for a 4000 all purpose, you'll still need to swap all of the components listed above but won't have to fab steering linkage.
4000SU is a pretty desirable tractor, you might be better off selling it and finding a regular 4000 or even upgrading to a 4600.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong.
... [Read Article]
Latest Ad:
Scraper 16 yard carry type. Southwest welding manufacturer company, Alhambra California Made around 1938.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
