JimFord555
Made a little rig to check torque converter endplay the best I could. Im confident in saying its .045 but couldnt find a spec in the manual. Thanks for your previous response Bern .025 - .050 max endplay put me just under the limit !
The potential crack in the drive plate looks good after further inspection
The TC is welded and the manual says the only maintenance other then a stall test is cleaning with a commercial torque converter cleaner or a paraffin base solvent so thats one of my next steps
My 555 unit number is 9D09B (9th day in April 1979 day shift)
Manual says an improved durability torque converter was incorporated into production @ Unit # 9E09. (Exactly 1 month after mine was built) they are interchangeable.
With everything on my plate and my machine work almost complete I feel this TC is good to go back in after cleaning
If i did have future problems would I be removing the trans from below to access the TC or splitting the tractor again ?
Can anyone recommend a rebuild kit for a Lucas CAV DPA ? Other then what comes in the kits and replacing the Veins is there anything else I should be looking at ?
Here is an update video
https://youtu.be/UoTlOTE-9uw
