I recently bought a 861 Ford Diesel Powermaster that had been disassembled 40 years ago. I am now reassembling
the engine. I am reusing the original pistons with new rings and rod bearings. The rod bearing cap bolts and
nuts are present; however, I find no washers in the bucket of parts. Can someone tell me whether the 172 CID
engine uses any kind of lock washer, safety wire, or tabs on the rod caps?
Also, should I use new bolts and nuts?
I am not an experienced mechanic; any advice will be sincerely appreciated.
