My 860 lift is strong but will leak down and go back up with bush hog in position control(Maybe 3 or 4 inches). I have overhauled lift cover including with all new o-rings and seals. With a heavy disk I raised it up and shut off engine.(Had oil filler at top and inspection plate removed). The only place I see a leak is on control valve at turn buckle. The lift piston does not leak. I know manual calls for new bushing and control valve of which I believe are no longer available. Any tricks. I use it all the time. Do I just live with it?
I thought I posted this yesterday but could not find it today.
