Re: Need advice on converting vertical exhaust to hori
MarkB_MI
Location
Motown USA
One thing I should mention is I had trouble getting the fan belt to clear the pipe on my row crop. Mine has been converted to 12 volts and I couldn't find a belt that was long enough to fit on the pulleys while short enough to get tight without hitting the exhaust pipe. I installed a different alternator pulley from Steiner and that fixed the problem. I don't know if this will be an issue on a standard tractor.
