Power adjust rims
1 of these rims needs a little work. Other seem ok. Suggestions on repairing the bad rim? What are the good ones worth?
As Destroked said, patch the hole and either drill a new hole there
or somewhere else on the rim. I usually put them 180 degrees
away from the original hole just to keep them far apart.
If you drill a new hole be advised that if it is drilled in a location other than the OEM location, adjusting the rims to end of travel break off the valve stem.
The hole is where it is for a reason.
Dean
