JimFord555
Re building the engine on my 1979 pre letter 555 backhoe that came stock with no turbo. This one has an API turbo added. It ran great from what I could tell before the hole in the cylinder (reason for rebuild) but now Im trying to decide to get rid of it or keep it. I want reliability and I plan to only run the machine on my 5 acres. I have been told that the pump and injectors in stock configuration with the turbo will add a little more power, not excessively wear the engine and burn the diesel cleaner. If i remove the turbo I need to cap off the oil lines to the turbo, re configure the air intake and weld up/ bolt the exhaust stack back onto the manifold. Is keeping the turbo a big risk ?
How can I fix the hard fuel lines that feed the injectors ? They leak at the injector pump fittings.
Pump says
Lucas CAV ser.21291SD
DPA 3233651
Since the torque converter is out I would like to service it but its welded together. Is servicing necessary ? How should I proceed ?
Here is a video of that Im into
https://youtu.be/C7TNUBurKoE
Pump says
DPA 3233651
