Hello guys. Got another issue. Bot a 45 mm block heater for the ford 1500 with the 2 cylinder shibaura engine. Thought I read something about it going in on the left side which has a 45 mm plug. Well I knocked it out this afternoon and there was the camshaft behind it. Looked around and there are plugs on the right side in the side of the block and the head between the glow plugs. I don't really see any place there for an block heater. The plug in the head is 45 mm but I pulled the intake hose and can see the valves and there is no room I can see on the inside to put a block heater. The plug on the lower side of the block is larger than the others. Luckily Oreillys had a replacement plug for fifty cents (the cheapest thing I ever bot there.)
Question is whether there is a place for a block heater or not?
If not then I'll get a lower radiator hose (1 1/2") heater. Thanks.
