2110 LCG update!
Lynn Patrick
Got the tractor split & the clutch out. Looked REALLY GOOD - for a little while. Then noticed the piece w/the set screw on one finger was broken off. Found it in the rear of the clutch housing. I already ordered a new clutch complete w/pilot & TO bearings & centering tool.
These sure are totally different than the 100 series 2 stage!
Can you post a pic of the clutch? you have me wondering about what is different. Thanks.
Biggest difference is that one disc is separate from the "package".
And the piece broken off from the top of pic
Them links breaking is pretty common. They slingout, wear on pin then break. If caught soon enough can be turned over, They may have allready been turned .
