I was wondering how many different axle configurations were there available for the conversion kit Elenco made for Ford tractors? Ive seen the type with a bolt-on differential cover then others were it is welded on and still others that have "ELENCO" cast in them. And that is just for the 600-800 type tractors- the industrials had a totally different type of axle!
Also, how many different gear ratios were used, and is that stamped anywhere on the axle or do you have to remove and visually inspect the gears to know??
