tractorguy2
I'm pretty sure one of the steel lines inside the clutch compartment on dads 641 is leaking. Hydraulic fluid drips at a pretty good rate out the hole
in the small inspection plate on the bottom of the clutch housing. It's not coming from the transmission. The trans fluid I found had a fair amount of
water in it. So I draining it and replacing it. What is dripping on the floor is nice clean fluid jut like what is in the hydraulic reservoir. The
tractors hydraulics only operate the blade on the front by means of the remote valve on the top cover. Tractor has a Sherman backhoe so no 3pt.
I can find very little information on the pipes in the IT manual or in my Ford parts listings. Can find no reference to part numbers for the pipes or
any seals for the pipes. Anyone ever have a hydraulic leak inside the clutch housing?
