Fuel Shut Off Valve Rebuild on 801s
A while back one of you mentioned you were rebuilding these valves after the many failures of the new ones that are available. I've come to the same point
of wanting to try it. Can you post a description of what you did to remove the bottom rivet and replace the interior seal. Any other info would be helpful.
Thanks
I think the 801 has the lever style instead of the screw? The lever style you would have to remove the crimp that holds the washer under the lever. The screw style. I used a end cutter plier to grab the rivet and pull it out.
No the 801’s have both types . 1957-midyear 1960 have the screw type shut off , midyear 1960-on up have the lever type shut off right until end of production in December 1965 . Tony
