Kriskringle
New User
Well I'm back........Did more research. The tractor is apparently a 1962 Ford light industrial. It was orig buff but is now red + gray.
Pulled shifter top plate off.... ugly oil. Top bar visiblle was seized, easily freed up.By not moving it was preventing the shifter from shifting in the right side position ...ie.. 1 st and 3rd gears. All good now the not so good...still won't locomote.Has a gear shifter on the left side of the trans. just in front of the clutch pedal.Has a loader and large backhoe. Any idea if it is a reversing trans ? It is within the trans housing not another add on trans. Also think I have a stuck valve.
Is this tractor worth fixing? Paid 1200 dollars for it.
