Not used on any FORD. The FORD 9N/2N Industrial AND the Ford-Ferguson wartime Model used the M/S TSX-38 carb, p/n 2N-9510 -see below.
MARVEL-SCHEBLER CARBS USED ON THE FORD N-SERIES TRACTORS
The original TSX-33 has a large round knurled splined thumbscrew as the main adjusting needle with a spring tension clamp to keep it from moving. Since the TSX-241B superseded all other N carbs, the newer Main Jet screw would be correct on any N carb. FORD UPC nomenclature designates carburetors as group #9510.
Marvel-Schebler model & (Ford Part Number):
TSX-33 (9N-9510) - thru s/n 260596
TSX-38 (2N-9510) – used in ’43 on Industrial Tractors and the Steel-Wheel wartime model only. Uses the double throw choke lever as a 2nd choke rod ran to the front grille. Mid 1943 declared obsolete and Ford went back to the TSX-33 as standard 2N production ramped up. The TSX-33 carb was used up thru mid-8N production.
TSX-241 (8N-9510) - thru s/n 276115
TSX-241A - thru s/n 313112
TSX-241B - thru s/n 313112 up
TSX-241C - used on early 1952 production, cheaper construction, had no econo jet
but was superseded by the TSX- 241B unit that eventually also superseded all others.
Other Ford Carbs:
TSX-428, EAE9510C, B2NN9510A, NAA
TSX-580, EAE9510D, B4NN9510A, 600/700
TSX-593, EAF9510D, 800/900
TSX-706, EAF9510G, B6NN9510A, 800/900 –used on early models
TSX-692, 310746, 601/701
TSX-771, 312778, 801/901
TSX-662, 310015, 801/901 –used on mid-production models
TSX-769, 312955, 801/901 –also used on mid-production models
TSX-765, 312954, B8NN9510A, 601/701
TSX-813, C0NN9510C, C0NN9510G, 801/901/4000
TSX-33 - 9N, 2N, EARLY 8N
TSX-38 - 9N/2N INDUSTRIAL & 2N WARTIME MODELS ONLY. Mid 1943, declared obsolete, reintroduced the TSX-33 unit and used up thru early/mid 8N production.
TSX-241A, 241B,TSX-241C - 8N
FORD-FERGUSON 2N WARHORSE w/TSX 38 CARB:
*NOTE: The M/S TSX 38 Carb, Ford P/N 2N-9510, was only used on the Industrial and Warhorse Models as it used the double throw choke. Observe the choke knob on RH dogleg.
[i:654c4848f0][b:654c4848f0]<font size="4">Tim *PloughNman* Daley(MI)</font>[/b:654c4848f0][/i:654c4848f0]<table width="100" border="1" cellpadding="0" cellspacing="0" bordercolor="#000000"><tr><td height="25" colspan="2" bgcolor="#CC0000">
<font color="#FFFFFF" size="3">*9N653I* & *8NI55I3*</font>​
</td></tr><tr><td>
</td><td>
</td></tr></table>
Again, some voluminous misinformation. According to "Ford Tractors Carburetors" by Marvel Schebler, page 1-1 on the top left it clearly states the TSX-83 is used on the Ford 9NA industrial engine. Look it up, it's there! Very similar to the TSX-38 and could easily be adapted to use on the N tractors.
