Tractor is a ford 3000 with a 3 cylinder diesel. Would like to bleed the hydraulic system. Tractor is a 100 miles from where I live. Would like to bleed the hydraulic system. Want to use a hose barb with a piece of clear plastic hose to start tractor run it and remove air from the system. Will run the clear plastic hose from the external hydraulic pump which is run by a gear on the camshaft to the hydraulic pump.
Would like to remove the pipe plug on the pump and install a pipe fitting with a hose barb.
Thank you
hySulix pump is used to run the 3 point
Thank you
