tripper225
First of all I want to thank Ultradog MN and Sean in PA for help on earlier posts.
I believe that I have a unique opportunity to add power steering and and a light industrial front axle to my 850. My problem is that the tractor that has these items attached has a bolster that is bent and a hack repair job. see below. There is a permanent gap between the engine block and the bolster. You can also see a rod welded to the bolster that had the other end welded back on the tractor.
When I go to the CNH site and check out the bolster documented for the 2030 tractor I find this, but no part number.
Can you tell me what the part number for this is, and a fair price for it?
Another question is that my tractor bolster looks like this with no threads on the axle pin. The lowest holes mount my snow plow. Does the bolster shown at the CNH site have these holes?
Can I mount the front pump through hole in the axle pin?
I can't get into the CNH site. Can you tell me the part number of the axle pin and axle bushing in the CNH image?
