Ford Tractors Discussion Forum |
ford 6600
Author |
[Modern View] |
bobwhitecar
01-13-2021 15:26:43
got in a early 6600 tractor that filled the crankcase with coolant, i figure a pin hole in the cyl, is the most likely cause, seem to leak coolant pretty fast so i wasnt sure it will be a pin hole, any chance of a head gasket failure to cause it
MikeJM
01-13-2021 16:48:08
Re: ford 6600 in reply to bobwhitecar, 01-13-2021 15:26:43
Couple of ways coolant to get into the oil.
Pin hole in the cylinder, will slow down when a piston is covering it. Head gasket, usually into the top side of the piston, slow leak into oil pan. Any of the cylinder core plugs under the valve cover, had it happen, pretty fast leak and easy to fix. Cracked head or block, least likely, seen two different blocks crack from the oil gallery into coolant. Puts oil into the radiator too.
TGP
01-13-2021 16:44:35
I concur with Tracy Brown.
Dropping the pan and charging the coolant will quickly
Tell the story.
Tom
tracy brown
01-13-2021 16:23:53
I would suggest dropping the oil pan and pressurizing the cooling system.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains?
... [Read Article]
Latest Ad:
Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
