Company Logo Shop Now
Order Ford 861 Parts Online
861 estimated value
Mr. T. Minnesota
01-12-2021 09:50:37
Forum members,
Considering purchasing an 861 Ford in good to very good condition. What are the price ranges low to high? I understand there are a lot of variables. Seller says it is in very good condition but needs a tune up. I have worked with this vintage 172 engine before and have a little insight into its workings. Any and all info is appreciated.
Lanexa Speedway
01-14-2021 13:23:50
 Re: 861 estimated value in reply to Mr. T. Minnesota, 01-12-2021 09:50:37
Oh and it has factory remote hydraulics also. :)
Lanexa Speedway
01-14-2021 13:21:27
I agree with what the others have said on value. Just FYI and another pricing reference point, as well as a shameless plug for myself:
I have a 1955 860 for sale presently with the 172 gas engine. Has very good, matching 13.6-28 rear tires, heavy pie weights, factory split front wheel weights, Rest-o-Ride seat, swinging drawbar, and I can't remember what else. Original tractor with great tin, needing paint. Runs flawlessly, no smoke and great oil pressure. 12V alternator conversion. Starts instantly hot or cold. Good clutch, and good hydraulics. Turn-key worker, could be a fantastic restoration piece if desired. My price on this whole rig is $3500. It's on eBay right now. Located in south east Virginia.
Just thought I'd mention that.
Thanks,
Kevin
showcrop
01-13-2021 02:59:07
Mr. T. I have a 971D. I agree that "need of a tune-up" is likely to necessitate a full pump service. I sent mine out to a fellow here on YT 6-8 years ago and it came back no better. Three years ago I got it done at the local shop and that rebuild made a huge difference. It cost me $701.00. I use mine around 50 hours/ year.
showcrop
01-12-2021 14:30:13
In need of tune-up is likely to mean that it is very sick because if new plugs and points would make it run good he would have done that. $500.00- $5500.
Mr. T. Minnesota
01-12-2021 15:30:30
 Re: 861 estimated value in reply to showcrop, 01-12-2021 14:30:13
This 861 is diesel. I have worked on a 172 in the past and tune up could be filters and possibly injector pump cleaning which could be expensive in Minnesota- $800 plus. Bottom line is I will just have to test it out when I do a close up assessment and try out.
Colin King
01-13-2021 17:43:04
 Re: 861 estimated value in reply to Mr. T. Minnesota, 01-12-2021 15:30:30
Eric Rogenkamp of Eric's Machinery in Bluffton, MN has done work on both pumps and injectors for me. He's very reasonable.
Dean
01-12-2021 16:02:35
I am not a fan of the early Ford 4 cylinder diesel engines.
These engines are conversions from gasoline engines and produce about 5 fewer PTO HP than do contemporary gasoline versions.
They are also well known for crankshaft failures, whether equipped with balancer or otherwise.
Dean
Mr. T. Minnesota
01-12-2021 13:30:35
Thanks for the reply! I am not familiar with "hydraulic valve"? I am also checking on power steering.
TractorTucker
01-12-2021 14:01:15
 Re: 861 estimated value in reply to Mr. T. Minnesota, 01-12-2021 13:30:35
Valve that replaces the top cover to run rear hydraulic remotes. Just type ford 861 hydraulic remote into google.
JMOR
01-12-2021 13:14:52
Tires can be a significant portion of money in old tractors.
Look carefully.
Michford
01-12-2021 13:04:11
Condition is part of what drives a sell price, other things that factor into price is what is are the options or add ons with the tractor such as power steering, pie weights, or hydraulic valve. Ballpark $3000 to $5000 without more info.
Today's Featured Article - Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains? ... [Read Article]
Latest Ad: Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
