Front axle upgrade for my 850
First of all I want to thank Ultradog MN and Sean in PA for help on earlier posts.
I believe that I have a unique opportunity to add power steering and and a light industrial front axle to my 850. My problem is that the tractor that has these items attached has a bolster that is bent and a hack repair job. see below. There is a permanent gap between the engine block and the bolster. You can also see a rod welded to the bolster that had the other end welded back on the tractor.
When I go to the CNH site and check out the bolster documented for the 2030 tractor I find this, but no part number.
Can you tell me what the part number for this is, and a fair price for it?
Another question is that my tractor bolster looks like this with no threads on the axle pin. The lowest holes mount my snow plow. Does the bolster shown at the CNH site have these holes?
Can I mount the front pump through hole in the axle pin?
I can't get into the CNH site. Can you tell me the part number of the axle pin and axle bushing in the CNH image?
Unfortunately the parts site does not list the part numbers for the bushing or pin for the light industrial models, which usually means that they are no longer available new.
(quoted from post at 19:17:52 01/11/21) Unfortunately the parts site does not list the part numbers for the bushing or pin for the light industrial models, which usually means that they are no longer available new.
Thank you Sean in PA. Do you know anyone who owns a 2030 or one of the other sub-models that has the light industrial axle and could share what their parts catalog lists?
I only have a PDF of the parts manual for the later 3 cylinder models. There are a number of folks on here that have hard copies or old PDF's of the parts lists for tractors of that era. Hopefully one of the will jump in and offer some help.
I just have a parts book for the 4
cylinder tractors from 53-64. The picture
of the bolster looks identical to the one
you found down to the reference numbers
though. I hope this helps.
Thank you Tractor Tucker. Well done.
I just did a google search on C0NN3029F and C0NN-3029-F and it appears that this part is as common as hens teeth. There isn't even an image let alone a for sale listing.
I keep wondering if C5NN3A042 will work. I will have to find the part to attach my sheet metal or fab it, and fab a part to attach my snow plow, but it may be stout enough to support the light industrial axle.
Can I get some confirmation from anyone who has experience with this support and industrial axle?
Jim
tripper, if you were to share your location you may have a few guys in your area tell you of a few 800s in salvage yards in your area with good repairable front ends.
(quoted from post at 12:46:05 01/14/21)
Thank you Steve Brussel. I can try there.
Regards,
Jim
Jim, stop a few miles before you get there to get a coffee for Jeff. You need to get him in the right frame of mind to go out in the yard to look.
Jim, stop a few miles before you get there to get a coffee for Jeff. You need to get him in the right frame of mind to go out in the yard to look.[/quote]
Thank you Showcrop, I will do that and say that you send your regards.
Jim
