Loader for 5000
FlTim
New User
I have found a Ford loader and need to know if it will fit my 5000.
The numbers on it are CL28516. 19-857
I have a loader on it now but it is in terrible shape. The previous owner used it hauling trees and clearing land. Any help would be greatly appreciated
The parts site shows 19-857 as being the loader that was used on the 445, 445A, 450 and 545A Utility/Industrial tractors, which were all 3 cylinder models. So the loader frame is likely not long enough to reach the rear axle of a 4 cylinder tractor like the 5000. You can always fabricate an elongated bracket that will provide a mounting point in front of the rear axle for the loader frame. That is how the Freeman Loader is mounted on my '73 4000. It was advertised as having come off of a 3 cylinder 4000, and I assume that it had because it already had the brackets bolted to the rear of the loader frame. The bracket mounts under the axle and the loader frame mounts under the bracket so that all forces from heavy loads end up pushing up against the bottom of the rear axle just like a loader frame without the extra brackets.
(reply to post at 09:33:03 01/10/21) [/quot
Thanks for the information. I guess I will check it out and measure the width. I'm guessing it will be strong enough to stand up to my 5000. And I may be able to use some of my brackets that I have]
