Ford 7000 Brake Cylinder
cmw
New User
I am trying to locate the brake cylinder part number so that I can purchase it. I have purchased for this Ford before a Brake Rod Seal, Part Number C5NN2N336A & a Brake Shaft Seal, Part Number
D9NN2N289AA.I need the Brake Cylinder (Actuator on Transmission) that will work with these parts Can anyone help???
Ford 7000 tractors had mechanical activated brakes. No brake cylinders were utilized as the brakes were not hydraulic activated. So "no part number" for "brake cylinder".
I think you need to explain what brake cylinder you are referring to. As Old Ford Mech says there isn't one on a 7000. The brakes are manually applied when you push the pedal down, and the rod pulls directly on the discs in the axle trumpet. There is nothing on the transmission unless you are looking at maybe a euro hand brake or it has a hydraulic trailer brake system fitted maybe?
