Ford 3600 gas timing marks?
compressor59
New User
A big thanks for all the replies from my last thread. Last year I had a issue with the distributor not working and had to make a new bushing for the points plate. I had the distributor out and marked it but did not put a timing light on it. I hooked up a timing light and I can not find the timing marks. (Old Eyes). What side is it on??
Also my hand throttle will not work and hold. It will raise the idle a bit but it pretty much rotates freely. I tightened the spring tension but it has no effect.
The throttle has a cork washer that keeps the throttle set. Yours probably needs replaced.
Look on the bell housing below the starter for an inspection hole. Your timing marks are on the flywheel.
