Company Logo Shop Now
Order Ford 3000 Parts Online
ford 3000 PTO
farmer656
01-02-2021 15:45:50
I just pulled the PTO to replace seal, that went well, in putting the pto back in it would not go, looked up into back of housing and there is looks to be a gear hanging down where the PTO slides into the trans, what happened, PTO came out nice and smooth
Ultradog MN
01-02-2021 16:45:31
 Re: ford 3000 PTO in reply to farmer656, 01-02-2021 15:45:50
Sounds like you have a twin stick model.
Also sounds like you don't have a manual.
I&T FO-31 says on twin stick models to engage pto handle before pulling the shaft or the splined coupler will fall out of place. Remove the cover the pto handle goes through to put the coupler back in place.
farmer656
01-02-2021 16:57:03
 Re: ford 3000 PTO in reply to Ultradog MN, 01-02-2021 16:45:31
Thank you so much.you are correct, no manual. again thank you and Happy New Year
Today's Featured Article - Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO ... [Read Article]
Latest Ad: combine ih 303 403 101 151 503 615 with grain plat header control [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
