I picked up a 960 project a few years ago. Serial # 92403 - (1956). Got it together and running decently. Used it to mow and had issues with transmission fluid escaping into the clutch/bell housing. I split it today to replace the two seals associated with the transmission/pto input shafts.
I have found an issue beyond a leaky seal and that is the PTO input shaft is not supported by a bushing or bearing at the end where the seal resides.
Delving into the parts book, there was a change associated with the shafts during the XX1 run.
I am wondering if a previous owner mixed parts.
Is anyone here familiar with the differences?
Here's some pictures.
The longest piece is the transmission input shaft. It is retained by the pilot bearing on the small end and the transmission main shaft on the other. The PTO shaft is in the middle. It has a set of needle bearings under the splined (clutch) end to keep it centered on the trans input shaft. The seal area is the machined surface 4/5 the way to the gear end.
The gear end is quite loose on the transmission input shaft, like a quarter inch of play. It looks like there ought to be a bushing or bearing inside the PTO shaft to ride on the machined (now rather rough) surface of the trans shaft.
The only thing holding the PTO shaft more or less centered is the hard washer at the back of the seal.
The washer, the failed seal, and the buggered surface where forces are being applied where they should not.
#10 is identified as "bushing, PTO shaft, Rear 9" double" - it does not exist in my situation. Google is unhelpful in recognizing the bushing, I cannot find it. Part # NDA-787-C
Anyone have experience with this?
Thanks -
David
Thanks -
David
