6610 other steering leaks
David G
I fixed the cylinder leaks, but tt looks like the case to pump is leaking on my 6610, I am debating resealing or replacing. The tractor is hard to steer at low RPM's and you can hear <the pump straining, so do not know if seals will fix a worn pump. I have replaced the filter and am using Hyguard, not low viscosity HyGuard for the increased viscosity.
Advice?
reservoir to pump leaking or pump to engine leaking or the fittings at the back or bottom leaking?
making sure the spindle thrust bearings are good and spindles greased well.... might help.
