gregjo1948
Just rebuilt the J843 engine for a NH 1630 4x4 tractor. Putting the engine back in I couldn't align the 16 holes in the side frame with the 16 holes in the side of the block. The engine was tight to the bell housing but the front axle and side frame wouldn't go forward far enough to install the 16 mounting bolts. It lacked about 1/2 of the hole to allow the bolts to go in. I went under the tractor and removed the 4 bolts from the support plate that is the rear mount for the stabilizer bar. The stabilizer bar is the "rod" that keeps the front axle from moving back and forth. Once the stabilizer was detached at the rear end of the rod, the 16 engine mounting bolts were easily screwed into the block as they were supposed to. My problem now is I can't move the stabilizer bar back enough to install the 4 bolts in to the support plate. Why is the front axle about 1/4"-1/2" too far forward? How do I move it back? thank you, gregjo1948
