Dieseltech pump shaft oring
riveroadrat
I need to confirm #97 oring in CNH partstore is the correct oring for the pump driveshaft. Part number is 87036S92. I also need some umbrella seals. Call when you get a chance.
The O ring # looks right, but it's not really needed, it does not seal anything, just keeps the shaft from coming out easily when it catches the inner end of the steel bushing. E-mail me your address again and I'll send two shaft seals. Be aware, if the pump you're wanting the seals for has the retainer ring breaking down, the new seals WILL NOT do any good. Pump will need to come apart to clean out any broken retainer ring bits and/or metal shavings from the weight retainer pins inside the pump..
