7000 would creep forward sometimes when the clutch was depressed. Spilt tractor. Input shaft has a bad groove. Picture should be with this message. The inner
race of the pilot bearing does not touch the input shaft at this groove. The pilot bearing was hard to turn. Is this worn input shaft and pilot bearing causing
the tractor to creep forward with the clutch depressed?
Note I also posted this using Modern View. Posting again since it does NOT show up on the old style view.
Here is link to the original post. https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ford&th=687973
<img
<img
