Readytoretire
Looking at a Ford 4000 diesel tractor, was told it is a 1974 model row crop 36" back tires square finder . The tractor starts in the cold good, the lift works good and the transmission clutch works good. 8 speed transmission. No problem engaging the PTO but when you move the leaver to disengage the PTO it keeps running. If you turn the tractor off the PTO stays off until you engage the PTO lever again. Then to get the PTO to stop you have to disengage the PTO leaver and turn off the tractor to get the PTO again to stop turning. Anyone had this problem with their Ford 4000 tractor. Other than that the tractor runs good with just a little diesel leak around the throttle linkage. Thanks TC
