Ford 901 looking for sources on rear rim
Right rear rim is completely rusted through. looking for a good source to find new or good used to replace it is power adjustable see pictures
Also i am told this is a 1958 is that right?
Thanks
I've gotten rims from 'Walt's Tractors' before - three of them over the years. They take a new rim and weld the brackets on it. The ones I've gotten have worked perfectly.
I have a pair of vintage Ford power adjust rims with centers, clamps, bolts, etc.,in SE IN.
Dean
How bad is it rusted through, welder can patch some in cheaper than finding a good replacement. You need to get your center screw pads welded into a new one, so there isn’t a cheap new option.
Not looking for cheap. There is a hole completely through. Have thought about welding back together. Just checking options first
They are available again now. About $500 each plus shipping.
I have always repaired mine when possible.
This one was a little too far gone for my liking.
Unless you plan to enter it in shows,it's easier and cheaper to replace it with later model spin out wheels. The one's you have are pricy when you find them.
That one's air cooled to prevent overheating but it requires very high density air in the tires.
Dean
