Recently purchased ford 3000. 3 point hydraulics not working and has been used to pull things on the farm only for two years. Drained oil from differential
filled with correct fluid. 3 point works barely. We think the hydraulic pump needs replacement or repair. Have a tisco repair kit. Ford New Holland sells an
after market pump for $485. Have never worked on one of these hydraulic pumps. Many springs, balls, plus other parts.
Wanted to know what others have done: Bought an aftermarket pump or tried to rebuild the pump after removal from the tractor. Ford New Holland does not try to
rebuild the pumps We did bleed the pump still 3 point does not work correctly
Thanks
Chris
Have worked and repaired the hydraulic assembly under the cover on a ford 8N. Possibly the hydaulic cylinder needs repair
Thanks
Chris
