Josh M.
- Location
- Northeast Ohio
I’ve posted about this before but I’ve gotten a bit more information. So the issue originally was that my pto would randomly shut off while using it and it would take a bit before it would come on again, as well as the hydraulics being weak. So I talked to a friend of ours who was a ford mechanic and he said the pumps were probably wore and he did a pressure test and got low pressure readings, (non-dual power tractor). And just the other day I was on the phone and I leaned on the 3-point arms and they dropped a bit and sprung back up when I got off which tells me there’s air in the system. I was wondering if the hydraulic pump and pto piggyback pump shared a pickup tube. I also seem to remember the rear end being way over full when I first bought the tractor as if they knew it was an issue
