Company Logo Shop Now
Order Ford 3000 Parts Online
hydraulic pump ford 3000
ejensen
12-18-2020 12:40:29
Recently purchased ford 3000. 3 point hydraulics not working and has been used to pull things on the farm only for two years. Drained oil from differential filled with correct fluid. 3 point works barely. We think the hydraulic pump needs replacement or repair. Have a tisco repair kit. Ford New Holland sells an after market pump for $485. Have never worked on one of these hydraulic pumps. Many springs, balls, plus other parts. Wanted to know what others have done: Bought an aftermarket pump or tried to rebuild the pump after removal from the tractor. Ford New Holland does not try to rebuild the pumps We did bleed the pump still 3 point does not work correctly
Thanks Chris
Have worked and repaired the hydraulic assembly under the cover on a ford 8N. Possibly the hydaulic cylinder needs repair
Sean in PA
12-18-2020 16:17:28
 Re: hydraulic pump ford 3000 in reply to ejensen, 12-18-2020 12:40:29
The 3000 name was new in 1965 when the 3 cylinder tractors came out. There never was a 4 cylinder 3000.
With that being said, the hydraulic pump would be one of the last things I would suspect when the 3 point lift isn't working. Get a service manual and go though all of the troubleshooting steps. Since you've done a top cover repair on an 8N in the past it won't be foreign to you to pull the top cover on the 3000 and check everything out under there first.
ejensen
12-18-2020 16:22:01
 Re: hydraulic pump ford 3000 in reply to Sean in PA, 12-18-2020 16:17:28
Sean,
Thanks for the advice. We will remove the top cover and check out the piston and other parts under the cover
Chris
Mike(NEOhio)
12-18-2020 14:26:23
Three cyl. 3000 or four? Are you sure you got all the air out? Before you dive into a rebuild take the 3/8 hex socket plug out. Get a hose barb and length of clear plastic tubing to reach the fill port on the rear end and let it run a while and watch for bubbles. You may not see them when it's running but will if you shut it off. It could also be in the linkage, valve or cylinder. Pumps aren't hard to rebuild but don't just assume it's the pump. I put a Tisco kit in mine but had to adjust the ball cages with pliers so the balls were free to move.
ejensen
12-18-2020 15:43:49
 Re: hydraulic pump ford 3000 in reply to Mike(NEOhio), 12-18-2020 14:26:23
Mike,
Engine is a 3 cylinder diesel. Excellent about removing bleed plug use a hose barb, length of plastic flexixble tubing , let tractor run and drain through fill plug and check to see if air bubbles stop. Will try it. Thanks Chris
Today's Featured Article - Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO ... [Read Article]
Latest Ad: combine ih 303 403 101 151 503 615 with grain plat header control [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
