JimFord555
Here is a video of what Im into
https://youtu.be/TsY2sBTP_6Q
How do i check the relieve valve spring tension ?
The manual says:
Relief Valve Spring Tension - 1.07in. (27.2mm) under 10.7-11.9lb
(4.85-5.4kg) load
How do the roaters and wear surfaces look to you guys ?
Is regular oil good, or is engine assembly lubricant better ?
The manual says:
(4.85-5.4kg) load
