Re: Need help with Ford 860 and double clutch
WayneIA
NDA7048A ground drive shaft seal. NDA77047A PTO shaft seal. Ether take the flywheel off or fill the bearing
center hole with grease and drive a same size shaft into the hole , forcing the bearing out. Using a screw driver, pry the tail of the spring away from
the side of the transmission case to release the spring.
