3000 - gear selection problems
Hillclimber1
New User
I have had the tractor for a year and all went well. Today I could not move the gear lever into reverse, just would not budge. In neutral on the 1 to 4 +reverse lever, moving the high - low gear lever into either position, the tractor will move forwards upon clutch release. Trying to engage a gear without clutch, no sounds of teeth meshing.
I read on the Forum that the end of the gear lever where it enters the selector sometimes wears i.e. not moving selector correctly.
Any ideas or checks to make before I remove the cover and investigate.
Peter
Remove the cover and investigate. Look for wear on the ends of the shifter arm and shift rail gates. Most likely you'll simply need to align the gates, set the cover back down, and keep on going.
